Quantcast
Do I really have to buy a £200 ceiling mount?
P
Per Magnus
Hi!
I'm planning on buying a projector, and I'll have to get it ceiling mounted because of too small floor space. I'm on a bit of a tight budget and can't really see why a simple ceiling mount will have to cost me 2/10 of my budget.
That's why I have decided that I either have to go for a 2nd hand projector with ceiling mount included in the price, or I'll simply have to make one myself.
So I'm wondering what you guys are using? Have you all bought an original ceiling mount or did you make your own?
Is it easy to make one?
All suggestions appreciated:)
Best regards
Per Magnus, Norway
P
Per Magnus
Thanks for the advice guys!
I'll report back later with my solution, and how it went...
Per Magnus
