Do I need two amps to biwire
Bristol Pete
As above do I need two amps/rec to biwire or can I just put the wires into one binding post ??
Totally unsure on this subject.
Is it really worth it ???
Just got Mission M72 fronts that are b-wireable. Setting up on weekend and might as well do it if poss and it improves sound.
Rec' is Sony STRDB870.....
Thanks in advance.
Captain B.
kelvin
You can biwire using your 870 by simply running two sets of speaker cable from each binding post as you suggest. If you do a search on "biwiring" you'll see that whether or not it makes any real difference tends to be subjective...
Biamping is a totally different story however and it is perhaps by doing this that you'll notice more dramatic improvements...
Kelvin
Samsung S95B QD-OLED Review - A Quantum Leap for OLED!
