Do I need to reset Humax HDR when adding 2nd feed
Discussion in 'Satellite TV, Sky TV & FreeSat' started by alan47, Jun 11, 2009.
Tags:
  1. alan47
    alan47
    May 31, 2009
    29
    3
    Set up my new Humax HDR last week but only had one dish feed at the time so looped through as recommended in manual. Have now run a second feed to Humax but do I need to set it back to default and install again to recognise the new feed?
    Also, should I be able to record 2 programmes at the same time from the EPG or is it 1 + the live channel being viewed?
  2. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,436
    Redditch
    +4,159
    There are 2 ways of telling the hdr it now has 2 cables
    Factory reset - watch for 2 cables recognised message
    or
    Change Connection mode in the secret menu
    Enter the setup menu
    Press RED GREEN YELLOW BLUE GREEN YELLOW BLUE
    Change connection mode to 2 cables (same)
    You can then record any 2 channels and also watch a 3rd channel but the choice of what you can watch depends on the 2 channels you are recording.
    In some circumstances you can record 2 and watch anything else and also pause live TV on the 3rd channel. Incidentally you can record 2 and watch a 3rd with only 1 cable just with a more limited choice as to second recording and 3rd watching.
    When you have the 2 cables set up try this
    Tune to 108 BBC HD start an instant recording, tune to 951 BBC 1 CI and start an instant recording, now tune to any other channel and press pause. This should work fine.
    If you understand how it all works (or have a PC with Excel) you can sometimes make a channel you want to watch available by choosing a different region to record if either or both of the recordings have regional variations in the epg (BBC 1, BBC2 (2 variations), ITV 1 (2 variations unless you use a London postcode).
    If you have a PC this is automated in the following download for both single and twin cable installs
    4shared.com - online file sharing and storage - download FoxsatRecordCheck010.xls
    Graham
  3. alan47
    alan47
    May 31, 2009
    29
    3
    Thanks Graham. How do you know all this stuff:confused:
    Will try the reset but will I lose my recordings?
  4. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,436
    Redditch
    +4,159
    Lot's of messing :D. You won't lose your recordings, you will lose any non-freesat channels you may have added, all your freesat programme reservations and any personal setting changes you may have made from defaults.
    The secret menu option should not affect anything.
  5. alan47
    alan47
    May 31, 2009
    29
    3
    Thanks.
    Not sure if this should be a new thread but after I retune freesat is there any easy way of adding just sky 3 and sky news without going through the complete rescan process. Also, if I delete the channels I dont want, will they reload when the unit looks for new channels at a later date?
  6. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,436
    Redditch
    +4,159
    Yes there is go into manual tune and change the all to these 2 transponders in turn
    Sky 3 - 12260 H 27500 2/3
    Sky News - 11324 V 27500 2/3
    Delete the channels you don't want before saving.
    Can't answer Q2 as I don't bother deleting channels. Easy way to find out, delete a few and do a new freesat channel scan. Don't know what will happen on a auto new channels found scan, suspect you will get the deleted ones back.
  7. Snapman
    Snapman
    Mar 14, 2009
    258
    28
    +26
    I don't feel so alone here now I know there's at least one other member who doesn't want all the available channels, most of which, IMO, are rubbish, although I must concede that some viewers must like them or they wouldn't exist :confused:
    Yes, the Freesat channels will reload each time you allow a search for new channels :thumbsdow
    David
  8. alan47
    alan47
    May 31, 2009
    29
    3
    Suppose there`s not much point in deleting them then.:mad:
    Is it me:rolleyes: or are the instructions for the Humax HDR poorly explained.
  9. Snapman
    Snapman
    Mar 14, 2009
    258
    28
    +26
    I've deleted them but have to keep saying NO to updates.
    No, not just you, I for one also believe the user manual is poor. The bright thing though is that we've these excellent forums and Mr Thompson to turn to when we get stuck :)
    David
  10. alan47
    alan47
    May 31, 2009
    29
    3
    :clap: Reset and now able to set 2 recordings in epg.Thanks .Tried to alter transponder for sky 3 but it does not give me the option of 12260 h 27500
  11. alan47
    alan47
    May 31, 2009
    29
    3
    He`s got the patience of a saint:clap:
  12. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,436
    Redditch
    +4,159
  13. alan47
    alan47
    May 31, 2009
    29
    3
  14. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,436
    Redditch
    +4,159
    Changing the resolution only changes the hdmi output. The scart is always 576i. If you only use the hdmi for HD use original or 1080i
    Graham
