You do NOT need to stripe the tape, (That is the correct phrase for what you have done).
It is a waste of time and a waste of your camcorder head lifespan, (very bad)
Believe me, I am Pro Broadcast Video Editor.
What you have done is also called 'Blacking' the tape, and it is pointless if you are recording rushes onto the tape (rushes is the correct term for un-edited footage/material).
Striping a tape is only required when you are 'Laying Back' or 'Printing' to tape from an editing package to place your finished piece onto tape. And even then some edit systems don't need a fully striped tape as they can layback in 'Assemble Mode'.
Imagine a blank video tape as a strip of film without the sprocket holes, when you record on a camcorder (normally, using assemble mode - pressing the red 'Record' button), the sprocket holes (called Control Track in video terms) are put onto the film strip.
Hopefully you've got this so far...
Every time you record over the tape on the camcorder it totally erases the tape and the control track, and writes a new control track together with the new picture and sound.
So striping the tape is a waste of time.
What you should do is start with good working practices for handling tapes and timecode, but there are far too many issues to go over here, I could go on forever, stop me someone.
Basically after you have finished filming a shot, keep recording for a couple of seconds (3-5). If you take the tape out, replay it or have to change a battery, cue the tape up again in the camera to somewhere in the middle of that spare few second at the end of last shot.
When you start recording again the Timecode on the tape should pickup from where it left off, without resetting to zero. As someone has already said some camcorders have an 'end search' button, but it has only a limited use.
Also give all your tapes totally unique numbers starting at 1, label them B4 you use them, label the tape and the box. They will never get mixed up, and when you learn more about the Post-production process, you will understand why this is so worthwhile.
All the best,
Duncan Craig.
Peruse my new website at:
www.duncancraig.f2s.com
