Do I Need To Change Beta
Discussion in 'Xbox Forums' started by shocket, Sep 13, 2007.
Thread Status:
Not open for further replies.
  1. shocket
    shocket
    Jan 6, 2006
    174
    I got my code on monday night from us gamespot, i have read people saying that puts you on US servers, is that the case?
    I have my code from Game now so should i delete my original and re-download with the new code ,also will i lose my rankings if i do that or are they just stored against my gamertag, any help would be great
  2. Dirtschmooz
    Dirtschmooz
    Apr 1, 2005
    3,961
    +658
    keep playing with your existing download. The Beta is exactly the same.
    The matchmaking server should try and join you with fellow Uk players or where the connection is of similar quality. It also uses some form of truskill to put you with similar level players. Still a Beta so this bit may be ropey.
Thread Status:
