Do I need an amp for sky+
Discussion in 'Sky Digital TV Forum' started by doopydug, Apr 23, 2007.
  1. doopydug
    doopydug
    Apr 19, 2007
    393
    +21
    Just got installed last week and have a spare set of Logitech Z5500 speakers lying around. They have 5.1 TXH certified dolby digital and dts hardware decoder.
    Would like to hook em up to get surround sound - will i need anything else?
    Apart from a brain that is
  2. doopydug
    doopydug
    Apr 19, 2007
    393
    +21
    Any help out there?
  3. derbyjj
    derbyjj
    Feb 16, 2005
    238
    Rainhill
    +19
    Looked up the spaec of the spec of the speakers and all you need is an otical cable to connect your sky+ to the amp.
    You also need to go into setup and specify optical output aand dolby digital.
    PS only movies are in DD5.1 and some disney. Most other stuff is in prologic which your amp will decode autiomatically.
  4. doopydug
    doopydug
    Apr 19, 2007
    393
    +21
    Are you saying that the speakers have in-built amp? Is that what the decoder is?
    I looked it up myself but don't understand the terminology
