do i need a woofer
Discussion in 'Home Cinema Speakers' started by luv ya jen, Apr 6, 2003.
  1. luv ya jen
    luv ya jen
    at the minute im using a set of eltax jupiter 5.0 speakers £199.99 from currys im very happy with the performance and im wondering if i would be more impressed by adding a sub does it really make that much difference. by the way im running the speakers with a sherwood rd 6103 amp thank you 4 your time (thinking of the a6 atom sub from comet £79.99
  2. Howard0000
    Howard0000
    Jan 11, 2003
    953
    28
    Surrey
    +37
    I've heard that using cheap and nasty subwoofers is actually worse than not having one at all....
  3. nathan_silly
    nathan_silly
    Yeah, don't bother. I bought a Yamaha subwoofer off a guy on these forums.
    It's crap! :) I only use it very very low volume, just to add some detail to my standmounts for music.
    I would not use it for AV- it cannot cope.
    Agree with Howard, either buy a good one or don't bother.
  4. luv ya jen
    luv ya jen
    how much would you advise me on spending???
  5. dukebox_1st
    dukebox_1st
    Feb 2, 2003
    26
    Edinburgh
    i was running the liberty 5.0 (eltax) speakers without a sub til a few weeks ago where i added the eltax sub8 (unfort sub10 seems to b discontinued). i felt it made a tremendous difference and deffinatly worth it. to b perfectly blunt i don't seen that it would b worth plumping major money into a sub seems as the rest of ure system is only worth 200 enless u are planning on upgrading the main speakers soon.
    hope this helps
    tom
  6. Viker1
    Viker1
    If you plan on using it for home theater to bring out your lows and complete the entire home theater experience, then at least a 10" sub would be necessary. A sub of decent quality, for example a mission ms10, would run you about 250 pounds. Happy hunting!!
  7. roofer
    roofer
    Nov 21, 2002
    343
    northumberland
    +10
    would reccomend the velodyne vx 10 from uncle eric in the power buys this sub is great value sounds brilliant but you must give it time to run in and its only £ 199
  8. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    Hey guys ... this poster has £200 speakers and a £200 amp ... I think we can safely asume therefore he's on a budget ...
    Yes a Mission MS10 or Velodyne VX10 sub would be very nice ... but don't you think maybe a little over the top price wise ...
    Try looking around for a secondhand Paradigm sub ... the PDR8 or 10 would work well with your setup, arn't too big and are often avaliable secondhand on Loot, eBay or here in the Classified thread. Alternatively Richer Sounds may have one for around £120-150.
    The Eltax subs that Richer Sounds sell for <£100 will add some low end stuff, but you'll probably find it quite distorted, etc.
    Please ... let us know what you end up doing and how you find it ... a lot of us tend to forget about those on a real restricted budget so its nice to have feedback on how our advise goes.
    Vikki
  9. Mackster
    Mackster
  10. agw_01
    agw_01
    Nov 12, 2002
    169
    19
    Preston, UK
    Basically, yes... you do need a sub woofer.
    I was pretty happy with the output from my Mission 702e speakers, but when I got an Eltax Sub 10 for £60 from RicherSounds, I was totally blown away.
    I know most of the people here say "cheap subs are crap" or "having a cheap sub is about as sensible as licking the toilet seat in a public toilet :eek:" but seriously, from what I was expecting from a cheap sub... mine totally blew me away.
    If I set the sub up downstairs, it will shake the wardrobes upstairs... bass output is more than enough and I never have to have it over half volume to get a nice amount of bass.
    Maybe cheap subs do suck, but from what I have heard, you don't have to spend £££ to get a 10" sub that provides enough punch to keep you smiling, whatever you use it for.
  11. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    I'd bite his hand off at that offer - though you'll probably get told off for posting it here!
  12. Mackster
    Mackster
    Only trying to help out, I've seen other people do this in the past.
  13. nathan_silly
    nathan_silly
  14. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    Try RS for an Eltax sub 10 @ circ £60. They appear to be still in stock at the moment.
  15. paulfd
    paulfd
    May 18, 2002
    48
    Luton
    lmao
    :rotfl:
  16. SK-67
    SK-67
    Dec 11, 2002
    East Sussex
    Mackster
    If it is still for sale I would be interested in buying your Paradigm PS-1000, as I live on the Kent / E.Sussex Borders. How old is it, etc?
    Cheers,
    Simon
  17. luv ya jen
    luv ya jen
    thanx 4 all the replies ladsstill not sure what to do i have 80 squid to spend on either a sub or films if i was to go with a sub id get the eltax sub 8 from r-s 79.99
  18. luv ya jen
    luv ya jen
    just popped into the notts store of r-s asked for a eltax sub and the old r-s curse raised its head "sorry sir weve ran out" the chap then tried to show me another sub a GALE 3070 99.99 IS THIS ONE ANY GOOD?????
  19. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    No
    Your best bet is a second hand Paradigm. If there isn't one in the classified section now I'm sure that one will be along shortly so don't give up yet and buy something in a hurry that you will regret later
  20. agw_01
    agw_01
    Nov 12, 2002
    169
    19
    Preston, UK
    I paid £60 for my Eltax Sub 10 about 2 weeks ago.
    My nearest RS is in Prestwich, and they only had them in on that day... I got the last one :eek: they must be damn popular!
  21. MrPumpkinHead
    MrPumpkinHead
    I'm currently using a Gale 3080W (£150), happy with it's performance in both music and films.
    Also got the 3 year extended warranty which includes the 50% buy back. Seems a good deal to me.
    I assume the 3070 will be fairly reasonable, see if your local Richer sounds will let you demo it at home.
  22. Ziggy
    Ziggy
    May 22, 2003
    79
    Im a bit late on this one i think, but never the less.
    I bought a Gale 3070 Sub from R-S and i think its great.
    It makes a hell of a difference to the cinema sound in whole and really gives music a boost (either through the DVD or Sky music channels)
    Its the only sub i've ever owned, so I couldn't really compare it to any others, but i like it.
  23. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    jen
    Hiya, I've been in Nottingham RS and i'm not at all impressed with them. Their stock seems to be about 2 years behind any of the other RS stores i've been in (Couple in London, Watford, Milton Keynes, and Leicester).
    If you have transport I would recomend you try further afield the Leicester branch seems to have a larger range, more second hand as well as new kit and the staff there are very helpful.
    Of course others might disagree with this but the Nottingham store really did seem bad to us. They had stuff at say £160 when the other branches were selling the same items for £99.
    Steff
