Do I need a sub?
Discussion in 'Subwoofers' started by mercury, Oct 13, 2000.
  1. mercury
    mercury
    I was wondering if i need to add a subwoofer to my existing speaker setup. I have Eltax liberty 7s as main fronts, and Eltax HT bipoles as rear, my centre is an Eltax LR. It's all quite bass-heavy, unlike say Mission speakers. When i bought the stuff the dealer hooked up a really small passive sub and the difference was negligable. But if i want to add a bigger sub, would it make a real difference? And if so, in what price range should i be looking?
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
  3. Guest
    Mercury,
    I agree with Reiner. Unless you've got an active sub you're missing essential soundtrack and enjoyment. I'm not doubting your Eltaxs won't go low, but the sub has the power to amplify (is that spelt right?) the lows that you will only faintly hear now.
    I've got a Yamaha YST90. 100watts and cost me about £140. I was gonna leave the sub when I bought my kit, but the sales guy plugged in the Yammy and said give it 2 mins and you'll want it. He was right.
    My homecinema: www.danwright.atfreeweb.com/my_home_cinema_system.htm
  4. mercury
    mercury
    So i should look into a sub costing half the money i paid for my pair of main speakers?
    I think that would put me at around 250 pounds. Would i get something decent for that kind of money? I mean, i plan on expanding and i don't want to be stuck with a crappy sub. Can anyone recommend some good brands and models in the 250 range (or maybe a bit higher)?
  5. HT Dude
    HT Dude
    Get a REL Q50 or Q100e if you can stretch to it.
    The 50% of your speakers 'rule' is a very rough rule of thumb. I disagree with it, infact. I believe that even if you have a really ****e set of speakers, a good sub will make them sound much better than you'd think.
  6. D.Jay
    D.Jay
    Just as interesting is the high-end side of things. Most ( arrogant ) hi-end speaker owners claim they don't need a sub.
    They lie.
    I think in fact that in this case you don't need A sub. You want TWO subs connected at speaker-level.
    This is even more true if connecting to a bridged amp, where two subs are required to connect at speaker level.
    D.Jay
  7. Dave H
    Dave H
    Aug 20, 2000
    4,393
    Lots of different places!
    +144
    Hi I think you definately need a sub, I have cerwin vega at80's as main speakers on my yam dsp a1 they go very low but they don't have the control of my rel 100e .
    ps i am saving up for a secound 1ooe to improve it further, you can never have too much deep base!
    And the monkey flips the switch.
  8. Glyn
    Glyn
    Sub???
    Well, you dont NEED a sub but imagine this scenario, U buy a new CD, with 12 tracks on, you plonk it in and then it says that you can only play 10 tracks on your player. the last two tracks may not be essential on this CD but what if it happened on ALL? this is whats happening on your system without a .1 speaker. you wont miss what you dont have but what the hell, if you have spent hundreds on your collection then whats 200 pound on a sub?
    Also if you do add a sub then you can double/triple the volume of your system, you add volume for bass? well if you have loud bass to start with!
    No mother, You HAVE to watch it this loud, it is a waste of money otherwise.
    "I want to tell you a secret, I EAT dead people!"
  9. Guest
    Hi Mercury...
    Most peolpe find great improvements when they add a sub to their system, either in hi-fi, or in HC, whatever the price or characteristics of their system.
    From what I've been observing (and this is a personal subjective opinion), most people spend from 1/2 to the price of their main speakers price. If you have 100$ mains, look for a budget of 50 to 100$ for the sub.
    But remember, nothing is better than listening tests... Sometimes, you have good surprises from cheaper very good quality subs.
    Oh, and you should defenetly get an active sub...
    Rui
  10. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    D.Jay, what you say might apply to hifi setups, but in AV you will require an (active) sub connected at line level only. Using a sub for hifi-stereo is IMHO a matter of personal taste and a different story therefore.
    The Amplifier/Receiver can take care of the bass management.
    [This message has been edited by Reiner (edited 15-10-2000).]
  11. Phips
    Phips
    Oct 26, 2010
    Sorry - I'm new here and not sure if this is the correct thread - apologies if not. Seems I'm back in the stone age with the following enquiry but would still be most grateful for help:
    Request for basic advice:
    I have a Sony midi-system (record player, radio, cd & twin tapes). From this I run 4 pairs of speakers (only ever 1 pair at a time) via a Tandy 4-way speaker selector switch. The main speakers are a pair of Tannoy floorstanders, of about 1980 and these give a good, full sound. The second pair is the ones that came with the system and here is the problem – there is very little deeper bass.
    I would like to ask if I can improve the bass from this second pair (which are in a different room):
    Can I add a subwoofer to this pair?
    If so should it be active or passive?
    And what about the Eltax Rumble from Richer Sounds at £59?
    Or are better speakers the answer? The Sonys are 8 ohm bookshelf, max 40 watt (which is ample).
    Each speaker has only one pair of inputs – I have seen more modern ones with two pairs but do not know why they have them.
    Finally, it seems the trend is now for tall thin floorstanders, whereas before it was big square cabinets with a large diameter woofer and reflex port. Do the tall thin ones have a labyrinth type set up to improve bass?
    I learned all my speaker theory from the book by GA Briggs of Wharfedale, in the early 1970s.
    I really would be grateful for any assistance, and apologise for blathering on with so many questions.
    Phips
