Do I need a sound card?
T
tahoe joe
Despite all my home stereo hi-fi knowledge and experience, I've never bridged the gap between my PC and my home stereo. I've got loads of music on my PC in SonicStage. I know that I can simply hook up my PC to the stereo using a minijack-to-RCA cable, but is this going to get me the best sound? Or will a sound card improve the sound quality? I've read some postings that seem to imply that a sound card would be redundant in this case. I'm confused by all the sound card info out there, so any help or advice would be greatly appreciated...
:lease:
T
tahoe joe
Apart from sparing the processor, will a sound card actually improve the quality of the signal that is sent to my amp?
ijd
depending on the sound card and software but yes it should in as much as what you can do with it!
Chox1988
Thanks for the help...I've got my eye on this one:
http://www.echoaudio.com/Products/CardBus/IndigoIO/index.php
i dont know how much money you've got to part with but seems like big overkill to me, one of those on ebay is going for £100, which seems way over and above the job it needs to do.
http://cgi.ebay.co.uk/Creative-Labs...8QQihZ001QQcategoryZ75518QQrdZ1QQcmdZViewItem
^That does the job and should do it very well, although it is external, up to you obviously but the difference in price is huge compared to the difference i would imagine from the two cards, which wouldn't be noticeable imo if there was a difference in the first place.
T
tahoe joe
Thanks Abu, that price difference is enough to make me go for the cheaper external one. I'll give it a shot and let you know how it goes...
