Do I need a Primer (fixer) before using Ice Storm?
Discussion in 'Projectors, Screens & Video Processors' started by godi32, Oct 8, 2001.
  1. godi32
    godi32
    Hello again,
    I'm ready to start painting my MDF screen but I was wondering if I needed to put on a primer(fixer) first. I will probably be using a Sony projector with 1200 ANSI lumens. So I suppose Ice storm 4 or 5 is needed?
    Thanks,
    Dirk
  2. ROne
    ROne
    Dec 21, 2000
    782
    +8
    I just used thin coats, perhaps thin down your first coat, then apply 3 or 4 coats of thicker even paint.
