Hey dude thanks for the input.I think I read somewhere that the Elicit built in phono is based on and may be better than the Rega Fono therefore you may need to go up a step in the ladder to get a significant benefit I.e. up to the £500-1000 mark.
Depending on what cartridge you are running you may get a bigger initial upgrade in the sound by spending the £200ish on a new cartridge.
Yup. Haven't even considered moving on from the phono stage on my Elex R. Currently contemplating a cartridge upgrade though.I must admit I read the opposite that the Elicit R (and the Elex R) have pretty decent built in phono stages but not having owned either this is just from various reviews and comments on this forum.
100%. Endless colours and flavours. Amplification is limited in the changes it can bring, assuming it's up to the job.So I'm hearing buy a new cartridge not a fono?
The AT VM95 range have the added advantage of being the same depth as the Rega cartridges, so there will be no issue with arm-height and therefore VTA.... the AT VM95ML will give a good boost in both clarity and sound stage, the AT also has a long stylus life and is reported to wear records less due to its micro line / fine line stylus. At £129 it is a bit of a bargain.
MP110 is bonded elliptical, MP150 is nude and MP200 is nude with a boron cantilever. There are also slight changes in their bodies. Adding the MP200 stylus to my MP110 gave the detail of the 2M Blue with the warmth/ease of the MP110 - also much cheaper than a complete MP200.I also tried to map the Nagaoka series but they seemed to have a different grading/line system but I think the MP100 is bonded elliptical, MP150 isnude, MP200 uis Fineline and MP300 shibata (sort of).
But who wants a brown one?!May be of interest
Beware of anything that you're hearing over the Youtubes - it won't be close to what the original really sounds like.Ive been listening to the samples the ML highs are a lot more clarified
Theres MA files to download from dropbox.Beware of anything that you're hearing over the Youtubes - it won't be close to what the original really sounds like.
Ah, that's better. Still not direct, but a good bit closer.Theres MA files to download from dropbox.
