Question Do I need a headphone Amp for Fidelio X1
Nico72
I am completely new to headphones. I have just bought a set of second hand Fidelio X1 from the classifieds. The plan is to connect them to the headphone out of my SB classic.
Is the headphone amp in the SB classic decent or is it at smartphone level? Would I get a sizeable improvement if I spent another £100 in a dedicated headphone amp?
Nico72
Logitech squeezebox classic. It's a music streamer
DIBSTER
Nico
Hopefully you've got your Fidelio X1's set up and playing tonight (glad they arrived OK!).
In answer to your question I never used them directly from my Squeezebox Touch. However I have an Aune X1 Dac/Headphone amp ( £120/£130 new - mine was £50 2nd hand) and I found that this quite budget piece of Chinese technology made the Philips shine, and I preferred them through the Aune rather than the headphone output from my Creek integrated.
In the past I've had various Beresford DAC/Headphone amps and I reckon the Aune is on a par, and especially at £50 a steal.
Nico72
Thanks Dave,
I am listening right now. The headphones are as new. Very light and comfortable too. They are a bit quiet from the SB but still enjoyable. I have no alternative at the moment as i sold most of thevkit in my signature and went to active speakers. I will look into a dedicated headphone amp as they deserve one. Thanks for the advice.
Nico
DIBSTER
You will definitely find an uplift in performance with a dedicated headphone amp. There is a lot of choice in those these days. The Aune X1 is just one example, there are lots of others about. A good 2nd hand Beresford will also do a great job, but I have no personal experience of any other amps for your consideration.
Nico72
I have realised I had set a -20 dB offset on the analogue outs of the squeezebox. I have removed that and now the sound pressure from the X1is adequate without the need for a dedicated headphone amp. I might still browse the classifieds for a better DAC/headphone amp in the future to improve sound quality, but no rush.
