Do I need a Freeview Box??
Discussion in 'Freeview & YouView' started by Mose, Dec 9, 2004.
  1. Mose
    Mose
    Dec 1, 2004
    1,629
    Aldershot
    +149
    To be honest, me and the trouble and strife, are more into watching movies than we are sitting down watching the mind numbing crap on TV. Having said that, we have just moved house, and even with a high gain roog arial and booster, we still cant get a decent picture on the telly.
    Sooo....question!! Will buying a Freeview box make any difference at all to the picture/reception on my SAGEM AXIUM. If so, can anybody suggest a decent machine. Cost isnt an issue!!
    MOSE
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Depends on what your picture problems are. If it's a weak signal causing "snowy" pictures, then you're unlikely to get Freeview either. If your problems are due to "ghosting", then Freeview could be an option. The DigiFusion Freeview boxes seem to give as good a picture quality as Sky, in my opinion. Sky are also now doing a similar option to Freeview, for an outlay of £150 with no monthly subs, you can get a larger selection of free-to-air channels than on Freeview.
  3. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    If your TV is wide screen you NEED one
    Look at
    Sony VTX800, Pace Twin, Netgem IPlayer
