Do I need a DVD player that scales if I have a LCD?
Discussion in 'Projectors, Screens & Video Processors' started by Rob Sheep, Sep 8, 2005.
  1. Rob Sheep
    Rob Sheep
    Aug 17, 2003
    155
    16
    Worcester
    Hi, I've a Toshiba 37"LCD, and I want to know if I connect a DVD player without an in built scaler via HDMI (eg Pioneer 668) am I going to see a great deal of difference in picture quality from a player that does- say scale to 720p, as the screen has its own scaler?
    Is there any point in scaling a already scaled image? :lease:
  2. Mark_a
    Mark_a
    May 27, 2005
    3,062
    +611
    It all comes down to the relative merits of the scalers used in both. One's bound to be better than the other, but unfortunately there's no certainty as to exactly which one it's going to be. Chances are pretty good, though, that a dedicated external scaler would most likely be better than either of them.
    Regards
    Mark
  3. Dune
    Dune
    Feb 24, 2005
    264
    +15
    I just popped on here to ask a similar question to the thread title. Slightly different in that it is more general.
    There seems to be a lot of deabte about how high def LCD's handle SD images. Some say they are OK with DVD but when it comes to freeview or Sky they are awful.
    That has made me also wonder if you have an LCD do you need a scaler. But not just for DVD but for all your non-HD sources. The set top box, the DVD and even the old VCR.
    So the simple question is, will Freeeview (for example) look better on a HD LCD TV if you put the RGB output of the STB through a scaler?
    Dave
  4. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    From my perspective there is little between scaling in DVD player and panels, personally I seem to nearly always prefer to scale in the panel. Proper video processors do offer many advantages however re quality and convenience however.
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,550
    The Borders
    +3,025
    Hello all
    Rob Sheep - keep in mind too a Player with an inbuilt 'up-conversion' facility will only have limited output resolutions for you to choose from (480P, 576P, 720P and 1080i being the norm). If your LCD is not 1280x720 (which most aren't) then the up or down scaling in your LCD is still going to come into play.
    As Nick and Mark_a say the relative merits (or lack of) of one up-converter over another can really only be judged by watching a few video clips through the system and looking to see which option produces the least artefacts.
    Dune - if your LCD Display has the ability to accept 'Native Rate' Pixel for Pixel images at 50Hz and 60Hz then using a programmable external Video Processor to Scale, Deinterlace, Colour Balance your SD (and HD) signals makes a lot of sense.
    Even if you Display lacks the Pixel for Pixel option its definitely worth having a look at what an external Video Processor can offer you - often over sampling to something above the resolution of the Display and then letting the Display 'down-convert' works well.
    Best regards
    Joe
