do i need a better scart
Discussion in 'Blu-ray & DVD Players & Recorders' started by luv ya jen, May 21, 2003.
  1. luv ya jen
    luv ya jen
    hi guys im about to recieve a sony kd36" nx200 and a sony gdr nx7 dvd recorder and at the mo im using a sony dvpns700 with a sony 32 " tv connected with a bog standard scart would i be better using a more expensive scart to connect the 36" and dvd recorder. if so what would you reckon not silly money pls (upto max 50£
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    The QED scart range are relatively cheap (i.e. around/under the £50 mark) and offer a good picture quality versus performance compromise. Which you WILL notice on a 36" set. Your priority should be to put one between your Sony DVDR and whatever your source is (assuming it's not just analogue TV) as this is what you will be recording.
  3. home_bas
    home_bas
    Apr 9, 2003
    35
    I have a £30 Philex THOR scart from Richer, and it really does make a difference. 5* in What Hi-Fi too.
  4. kelvin
    kelvin
    Apr 22, 2002
    1,598
    Down South... (Bournemouth)
    +45
  5. themmings
    themmings
    Nov 21, 2002
    382
    Northampton
    +4
    Richer sounds do a couple of scarts, and if you are careful with the packaging you have a 14 day no quibble exchange.
    Buy a couple on the old credit card, try em' out - if you see a difference buy one, if not, take em' back and have them re-credit your card.
    No harm done.
    I use the Supra scart cable which is signal only (no sound).
    Tim:)
