Do i HAVE to use a DEDICATED CENTRE SPEAKER for my home cinema setup? or will any spe
Discussion in 'AV Receivers & Amplifiers' started by karl-ireland, May 8, 2007.
  1. karl-ireland
    karl-ireland
    I recently bought a brand new home cinema system (amp + speakers)
    Now one thing that didnt work was the center speaker (wharfedale 9.0cc)....
    So anyway,what i did was,i just switched the wharfedale centre speaker for an ordinary 100w loudspeaker....
    The sound seemed to be fine,but over the weekend,i had a marathon of films,games etc etc etc....and ive just noticed that the centre speaker is crackling and popping when i turn the volume up past a certain point??
    Will i have to buy a centre speaker?or can i use any oul speaker?
    Does it make a difference?does it HAVE to be a dedicated centre speaker??
    Id appreciate a response as it really is frustrating....
    Thanks for your time
  2. KMO
    KMO
    Nov 4, 2004
    431
    28
    Cambridge
    +56
    Any good speaker will do. The only special thing about a centre speaker is that it's in a horizontal form factor easier to fit above or below a screen.
    Whatever your centre speaker is, the tweeter wants to be as near the screen as possible, and as close as possible to in-line with the left and right speakers' tweeters. So if you stick a normal speaker on top of a TV you would want to turn it upside down.
    It should also be noted that the centre speaker does more work than any of the other 4 main speakers in films; its quality is crucial, and you shouldn't skimp on it. It may also be heavily used in multichannel music.
  3. rooo
    rooo
    Oct 12, 2004
    270
    +5
    You'd be amazed how much the speaker gets used, so it is very important to get this one right.
    The temptation is to skimp on it as I nearly did a few years ago, but it gets the most use in my system, especially if you like your older films which are just mono.
  4. Gregory
    Gregory
    Mar 27, 2005
    312
    Midlands
    +9
    There is often mileage in having all the speakers (or at least centre and fronts) from the same range. The characteristics are often more similar, so it can give a better integrated sounds.
    BTW, was there a reason you couldn't just get the failed speaker replaced. You said it was new?
    Greg
  5. chrisgeary
    chrisgeary
    Jul 23, 2003
    2,784
    Newbury
    +255
    The other vital role the centre speaker has it that of being magnetically sheilded. Not an issue if you don't have a CRT display of course.
  6. stew-b
    stew-b
    Mar 24, 2007
    71
    so plasma's arent affected by magnets? didnt know that :)
  7. karl-ireland
    karl-ireland
    Yea its all sorted..
    I bought the Wharfedale 9.0 cs speaker........
    the system is complete......(i feel complete)
    thanks for the replys.
