Hi I'm trying to figure out if I have a bottle neck or if what I'm experiencing is as good as it gets without spending hundreds of pounds upgrading
My understand is in theory with gigabit you can reach transfer speeds up to 125 MB/s
Transferring a 20 GB file from my PC to my Synolgy NAS took 35 minutes using windows explorer reportedly at around 11 MB/s
Even taking into account HDD read / Wright speeds that suggest fast Ethernet not gigabit ?
My main PC has 1 gigabit port built into the mobo this is connected directly to BT Home Hub 6 (Which has 4 gigabit ports)
the Ethernet status report this to be 1.0 Gbps
Again my understanding is BT Home Hub 6 is a modem & router it connects to the internet and assigns internal IP addresses to all attached devises both static, fixed, wired and over WH-Fi. It also acts as a switch.
This is connected to a Netgear 8 port GS08 gigabit network switch my Synolgy NAS (4 gigabit ports) is connected to this via two cat5e cables
See diagram bellow
The Netgear switch handles internal data transfer?
So the file going from the PC is going through both the router and the switch to get to the NAS?
I thought about adding a £10 pci-e card to the PC and having this connect to the switch not sure if this will by pass the router?
I'm hopping someone can clarify my understanding and if I do have a bottle neck suggest what I can do
Thanx
See diagram bellow
Thanx
