Do I buy a Screen or make my own? Advice sought.
Discussion in 'Projectors, Screens & Video Processors' started by Phil Hinton, Jun 27, 2001.
Thread Status:
Not open for further replies.
  1. Phil Hinton
    Phil Hinton
    Editor Staff Member
    Jan 18, 2001
    10,357
    3
    +8,835
    Hi Guys,
    I will have a Barco 800 at the end of July (hopefully!) and i am busy planning how it will be Installed.
    I plan to turn my Large Bedroom into a HC room and move into the smaller Room. The room is 14ft x 13.5ft and i am planning on a 89" x 50" 16:9 screen which will be fixed to the wall. I have many prices being quoted from £500 to £6000 (those nice Stuartscreen are very expensive).
    I have however recieved an e-mail from a forum member (wont mention names or quotes here) who has stated that just buying the screen material will be 60% cheaper and would just require building a frame myself.
    So the question is do I build one myself and save some money or go with a proper already built screen.
    Has anyone here built there own screen? What would be the advantages/disadvantages of building my own.
    I would love some advice as this in theory looks like the best route for someone as skint as me.
    The gain being used would be 1.5.
    Any advice or thoughts. :D
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    This is going to depend on your ability to make a frame that is true.
    The set builders at staging and rental companies often make their own screens by stretching material them across a frame. but it only has to last afew days!
    I guess your sigle greatest challenge is going to be getting the screen with no wrinkles and evenly stretched.
    I have seen screens made from painted walls and bed sheets. These screens were perfectly acceptable to their respective owners.
    I would have a go and let us all know how you get on. You can always upgrade to a "proper screen" if you are not happy with the results.
  3. Phil Hinton
    Phil Hinton
    Editor Staff Member
    Jan 18, 2001
    10,357
    3
    +8,835
    ^ Cheers mate! Anybody else got some advice, my diy skills are really bad, but how hard can it be................ :p
  4. Guest
    I made a screen for work! We needed one in a hurry but we haven't bothered changing it.
    I made a 6" wide 16:9 frame from some 2x2" timbers, took a roll of A0 paper and cut a large sheet off it and pinned it to the frame. Then took a sheet of matt plotting film, again frame an A0 roll, placed it over the paper & pinned it on. Then cut some beading with a mitre saw and screwed it to the frame, sandwiching the paper/film to the frame. Finished the beading with some matt black paint, screwed it on the wall and hey presto, a fully functional screen for about £10.
    When it gets dirty I just pin a new sheet of paper/film on it.
    Meat
  5. jlcrawford
    jlcrawford
    Mar 21, 2001
    491
    NE England
    +3
    I have made two frames the first from a Da-Lite model 4:3 which went ok but the material is flimsy and I didn't dare stretch it fully so it has a ripple in it but is totally acceptible.
    The second I bought stewart screen without the frame off AVS and this had snappers sewn into the seam I made a huge 4x2.5 frame and an upholsterer covered it with black velvet I got the material perfectly tensioned and it is 100% perfect and flat overall cost was £850 but I got stung by customs.
    But this is cheap for a 16:9 96x54 microperforated Stewart 1.3gain beauty
Thread Status:
