Do I buy a pronto?
Discussion in 'Home Cinema Control & Remote Controls' started by Shoka, Feb 5, 2002.
  1. Shoka
    Shoka
    Jan 10, 2002
    4,330
    Surrey
    +238
    It's my birthday and all my family have given me money, I think that the next addition to my HC should be a Pronto or similar. I've got £300 to spend and dont know whether to buy a pronto or somthing similar. If I did go for the pronto, what differance is the model with the base unit? Are they easy enough to programe? Any comments would be greatly appreciated.
  2. Spencem
    Spencem
    Oct 15, 2001
    197
    Northampton
    +9
    YES :D Richer Sounds are doing them for £150 without the docking station, so can can spend the rest on more DVD's.
    The docking station is just a battery charger, you don't need it to connect to a PC, that cable comes with the Pronto. £40 for a battery charger seems a bit steep to me so I am going to see how often I need to change batterys before I get one.
    As for proggraming it depends on how in depth you want to go. Have a look at remotecentral to see whats possible and their excelent FAQ on proggramming.
  3. Shoka
    Shoka
    Jan 10, 2002
    4,330
    Surrey
    +238
    I've read somewhere that you can change the background on them (like changing the wall paper on your pc's desktop). is this true?
  4. mjn
    mjn
    May 24, 2001
    22,728
    Herts, England
    +10,868
    Do you buy a pronto??
    Do bears sh*t in the woods??
    As for changing the background, you certainly can, i have some big breasted bimbo on mine....
  5. Shoka
    Shoka
    Jan 10, 2002
    4,330
    Surrey
    +238
    Whats it like to use it is relitivly easy? can you program it to do things like, turn my whole cinema on at the touch of one button etc? Does it work with tivo?
  6. mjn
    mjn
    May 24, 2001
    22,728
    Herts, England
    +10,868
    since its fully programmable, you can program it to do anything you want.....i've got mine to learn every remote i tried so far, over 12..including sky digital.
    It has macro facility, or you can make one button have several commands...
  7. Shoka
    Shoka
    Jan 10, 2002
    4,330
    Surrey
    +238
    Ordered one from Richer sounds about ten minutes ago, I'm sure i'm going to be visiting this forum a lot more often.
  8. mjn
    mjn
    May 24, 2001
    22,728
    Herts, England
    +10,868
