do i buy a dvd player with progressive scan,, or not
Discussion in 'Blu-ray & DVD Players & Recorders' started by tony m, Feb 26, 2002.
  1. tony m
    tony m
    going to buy a dvd player prob the pioneer 545
    but in the next 6 months will get a pt100 projector
    read that a progressive signal is the way to go for best pic
    quality
    will that alone totaly rule the 545 out
    or is it not that simple
    many thanks
    TM :confused:
  2. GarethH
    GarethH
    Aug 31, 2000
    325
    UK
    No the Pioneer 545 can't do progressive scan :-(
    If you want Progressive Scan at a cheap price, look at the Toshiba 510E which is about £400
    Otherwise push for the Pioneer 747A, which i should recieve tomorrow with a bit of luck :D
  3. Guest
    Please let us know what you think of the 747 when you get it.
