Do DVI> VGA cables convert the DVIout to analogue VGA?Hi All
Discussion in 'Desktop & Laptop Computers Forum' started by calvinhobbes, Feb 2, 2005.
  1. calvinhobbes
    calvinhobbes
    Hi All
    I am buying an HTPC that only has 2xDVI out, but it apparently comes with a DVI to VGA cable.
    I need to run VGA to my Sony HS50 projector as it is generally regarded as the best connection even over DVI.
    My question is whether the DVI > VGA cable converts the digital signal to a normal analgoue one that the VGA cable can carry, and whether there would be any difference vs just a VGA out?
  2. Berwhale
    Berwhale
    Jan 31, 2005
    23
    London
    It will work exactly the same as a standard analogue VGA output.
    The digital to analogue conversion is done on the GFX card, it just remaps some of the DVI pins to the same function as a 15 way D-sub socket. The DVI to VGA 'dongles' are just straight through connectors.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    DVI comes in 3 versions:
    DVI-A - analogue output only. It is just VGA through a DVI connection.
    DVI-D - digital output only. No VGA output is available, even via the converter you mention.
    DVI-I - this carries both analogue and digital.
    AFAIK the output from a graphics card is DVI-I and therefore to connect to a standard VGA monitor etc you just need the converter.
    Mark.
