J
JohnH
If you record using the analogue tuner on the recorder are you able to see the subtitles on playback?
I realise this is not the best source as far as picture quality is concerned but recording via the skybox would mean that the subtitles are permanently part of the picture. Whereas if this analogue surce worked I would have the choice to view the subtitles or not.
