Do DVD players have tuners?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Gades, Apr 8, 2002.
  1. Gades
    Gades
    Hi, I'm about to buy a DVD player (first time), and I was wondering if I could is it as a tuner as well.
    My TV's tuner doesn't work properly, so if I wanted to see any TV signal, I had to get a VCR (as they have their own tuner). So, if I buy a DVD (don't have a VCR anymore), will I be able to get my TV working again?
    Gracias!
  2. PhilipL
    PhilipL
    Jan 18, 2002
    3,854
    103
    +459
    No tuners in DVD Players, as it is a DVD Player.
    DVD Recorders have tuners to allow recording of TV in the same way as videos, but just to buy one to get a tuner would be rather an expensive way of solving your problem.
    Regards
    Philip
  3. Gades
    Gades
    Thanks PhilipL,
    I guess that I won't buy the DVD player then.
    But, if I find a second hand combo (the ones with DVD and VCR), even they don't look too good, I guess that'd be an option.
    Actually, my TV's tuner works fine, but it's a Spanish TV, so the sound frequency is different. That's why I need to get the signal from another thing like a VCR. As soon as I connect the TV througha scart cable (not the normal TV cable).
    Thanks for the inf., you've saved me about 80 pounds!
  4. PhilipL
    PhilipL
    Jan 18, 2002
    3,854
    103
    +459
    Your welcome.
    Can you not pick up a cheap video recorder, they are not expensive now, just go into Asda and pop one in your trolley :)
    Alternatively a car boot sale or something maybe.
    Regards
    Philip
  5. Gades
    Gades
    Thanks Philip,
    but I do not want to buy a second hand video. I did a few months ago; and it came up to be a bad idea. Even this video was quite new, there was a problem with its sockets. So every once in a while I lost my reception, or the movie would stop being recorded, and lots of little things. It really has a mind of its own.
    I have my own video as well, which I bought with the TV, but the tuner is Spanish as well.
    I thought that probably, it'd be a safer investment to get a second hand DVD player than a brand new cheap video. You can get videos for 60 - 80 pounds; and the same prize for second hand DVD players.
    Do you have any idea?
    Thanks again
    Fernando
  6. wellsi
    wellsi
    Mar 28, 2002
    494
    London, UK
    +29
    You can buy brand new DVD players for £99 and brand new VCRs for £65 from Argos...
    Cheers,
    Ian in London...
