Do Component leads carry sound
Discussion in 'Plasma TVs' started by hao, Dec 18, 2004.
  1. hao
    hao
    I was advised in a previous thread to connect my E55 to Pany AV4c using component leads. I read somewere else that I would also need scart to AV4 to get the sound, and in order to get some other functions which I cannot recall.
    Page 45 of the manual tells me that "Scart RGB and Component video cannot be connected at the ame time to AV4 as Scart has priority and AV4c cannot be selected"
    Hopefully someone will take the time to clarify this.
    As an afterthought would there be anything to be gained by connecting to AV2 at the same time as AV4c.
  2. astirling
    astirling
    Oct 1, 2004
    800
    28
    Dunfermline
    +44
    Component cables don't carry sound. ALthough you might not be able to select scart for video input it will probably still accept the sound signal.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    you set scart to composite and get sound and wide screen switching etc via scart but picture via component
  4. hao
    hao
    So if I have scart from Digibox VCR to E55 AV and comp cable to AV4c , do I connect AV1 on the E55 to AV2 or av4 on the sceen?
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    AV4 and set AV4 as Q-link for DVB recordings if you want to do that
    (digi box VCR scart is composite use digi box TV scart for RGB and better PQ (watched through E55 allowing for live pause etc with RAM disc loaded)
  6. hao
    hao
    Sounds Good (pun intended), dont get my kit till Thurs, but thanks for that.
