do any sky boxes have component output
Discussion in 'Sky Digital TV Forum' started by fatvdubbug, Jul 29, 2005.
  1. fatvdubbug
    fatvdubbug
    Do any sky boxes have component output ,coaxial or anything better than scart. :)
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Nope.
    RGB Scart, Composite Scart and two RF outputs for video.
    Twin RCA phonos for audio.
    SKY+ has the above and also includes an optical audio output and s-video.
    **There is a SONY standard digibox which has a non DD optical output and a Grundig standard digibox that has s-video.
    You can modify the original SKY+ with a SDI output and of course there is the option of taking the RGB scart output and via a convertor turning it into VGA or Component
  3. petecowie
    petecowie
    R.I.P.
    Sep 3, 2003
    884
    2
    Essex
    +42
    some sony/panasonic(?) boxes and sky+ are equipped with s-video not aware of any other video outputs available
  4. fatvdubbug
    fatvdubbug
    thanks for that
  5. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    Not a reply to the original question but if you are looking for a digital source that ouputs component Y Pb Pr as well as RGB without a converter then the Topfield does component through its Scart, switchable in the menu. You are of course limited to Freeview plus the option of TUTV.
    Scart of course is a kind of connection which can carry different standards like composite; S-Video, RGB or YPbPr component.
    Richard
