do any of these recorders support component out?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Bob Todd, Dec 18, 2003.
  1. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,080
    UK
    +373
    anyone?
  2. BigRD
    BigRD
    Jul 4, 2003
    393
    far far away
    +14
    The only one I know of at the moment is the Toshiba DR-1 as it supports PAL/NTSC Progressive scan.
  3. dazzer123
    dazzer123
    Sep 30, 2002
    398
    Stoke-On-Trent
    +3
    The Jvc DR-M1 supports component out and pal ntsc prog scan.
  4. clayts450
    clayts450
    Jun 25, 2001
    562
    2
    Nottingham
    +51
    Sampo DVE-R3 will support same as JVC when it gets released (yes, Ironduke - return of the killer toasters :))
  5. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,080
    UK
    +373
    lol sup Clayts
    hey clayts we all know u and sampo are inbed together.
    anychance of a bargain?
  6. clayts450
    clayts450
    Jun 25, 2001
    562
    2
    Nottingham
    +51
    Not presently, mate ;)
    We do have a good discount deal going with CTW Direct on Sampo's portable player, the DVE-P1 (this was at CTW's initiation, not anything we did - nothing in it for us at '450 financially) - nice bit of kit that is well worth the £312 they are charging :)
  7. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,284
    The Borders
    +2,573
    Ironduke
    If you have SCART RGB out on a DVR you could always add in a JS Technology RGB2YUV converter.
    Best regards
    Joe
  8. Davidedwards
    Davidedwards
    Sony RDR-GX3 has component out.
  9. Matthew Attoe
    Matthew Attoe
    Dec 8, 2001
    695
    Norwich
    +11
    Sony gx3
    But you can't use it if you're using RGB in to record from.
    Apparently.
  10. Professor Frink
    Professor Frink
    The Yamaha DRX-1 has (according to the manual) component out with Faroudja DCDi prog scan and also has component input.
  11. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,080
    UK
    +373
    no pal ps though
