Do all recent Toshiba TV's accept NTSC signals?
Discussion in 'Blu-ray & DVD Players & Recorders' started by ryonhill, Aug 17, 2002.
  1. ryonhill
    ryonhill
    I'm thinking of getting a Toshiba 220 multi region DVD player from richer sounds to go with my Toshiba 28w93b TV but is there any way to tell if my TV will accept NTSC signals from region 1 DVD's?
    I have checked the instruction manual but its not very clear.
    Any help would be much appreciated
    Thanks in advance.
  2. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    I would imagine most recent Toshiba televisions can handle NTSC 3.58 (pure NTSC). However in your case, it doesn't matter whether or not the TV does accept NTSC as I assume you will be using the RGB output from your Tosh 220 DVD player? If so, then the RGB signals bypass the need for NTSC colour decoding on the TV. Your TV just needs to be able to accept a 60hz signal which is more or less guaranteed :).
  3. ryonhill
    ryonhill
    thanks for the help
  4. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,906
    71
    50 Rue St Georges, Paris.
    +32
    It definitely will.
  5. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    I've been informed that the new Toshiba sd420e can process an NTSC picture and deliver it in Pal50 format. Ordered mine (multiregion) for £199.99 last night so I should be able to confirm this soon.
  6. sc1977
    sc1977
    Jul 16, 2002
    616
    kent
    +8
    iv got a tosh 28w8db and i have no problems with any signals ntsc rgb etc so any models up from that will be ok :D
  7. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Just using RGB out does NOT guarantee NTSC peformance. See my recent thread. In practice all current Toshibas to my knowledge will handle this with ease and have done for several years so you will not have a problem.
