Do all modern widescreen TV's support NTSC?
Discussion in 'General TV Discussions Forum' started by dwmoook, Dec 28, 2001.
  1. dwmoook
    dwmoook
    I am about to purchase a 28" widescreen TV. Are all new widescreen TV's compatible with normal NTSC as It will be used with my Pioneer DV530 which outputs native NTSC.. My 21" Hitatchi is fine with the output so I assume all Hitatchi's can support it. Are there any makes to avoide?
  2. mjn
    mjn
    May 24, 2001
    23,559
    Herts, England
    +11,973
    99% of the branded widescreen TV, will accept a NTSc signal, just double check on the specs from where ever you buy it from. Or if possible check the model number and information on their website.
  3. Doubledoom
    Doubledoom
    Some of the budget models don't as mjn says in his response.
    The Schneider 32" WS set being one example.
  4. brattle
    brattle
    Oct 12, 2001
    108
    16
    Bedford
    Make sure the TV can accept NTSC 3.58. There is another NTSC also known as quasi NTSC or NTSC 4.43 which will give a B&W picture with a pure NTSC signal.
