Do all denon 3801's have 2 prong plug hidden in 3 pin plug?
Discussion in 'AV Receivers & Amplifiers' started by dvdbrowser.com, Feb 10, 2001.
Tags:
  1. dvdbrowser.com
    dvdbrowser.com
    Does your 3801 have a two pin plug?
    If you undo the screw on your 3 pin plug and pull out the lead, a two pin plug appears.
    Is this normal or do i have an import model.
  2. Tony McG
    Tony McG
    I'm on to my second Denon amp and they have both been like this, all my new Sony kit also has these types of european type pug with the UK adapter thing.
  3. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    It's pretty much normal on this ort of kit, and yes most of the Denon gear comes with an EU plug with UK adapter.
    Rick
    'I am just a figment of your imagination.'
    Work Site: The Sound Gallery
    Home Site: WD A.V.
  4. mart.stokes
    mart.stokes
    Yup, I have an AVC-A1D from Hayden labs (so it is not an import) and the plug was just like as described above (before I replaced it with a Kimber Powerkord).
  5. Guest
    Oh no your equipment is broke [​IMG] its the dreaded 2 pin power supply inlet type problem again! arghhhh run run RUN
    LOL
