Do all Blu Ray discs have Dolby Digital 5.1 soundtracks?
Discussion in 'Blu-ray & DVD discs' started by petet66, Jun 8, 2009.
  1. petet66
    petet66
    May 11, 2006
    1,279
    63
    +157
    Apologies for the somewhat noob question but I'm building up to my first HD TV and Blu Ray player purchase and was eyeing up some potential first disc purchases in Asda this lunch time when I noticed that some of the discs made no reference to Dolby Digital 5.1 as a surround sound option (though they did mention DTS).
    I will not be able to afford to upgrade my AV receiver at the moment and it is Dolby Digital 5.1 only (not DTS). After a nervous half hour of Googling I found a website that says it is mandatory for all Blu ray discs to have both DD5.1 and DTS 5.1 soundtracks. Is that true? Or am I looking at a new AV receiver to get any form of surround sound from all Blu Ray titles? :(
  2. terry77
    terry77
    Jun 25, 2007
    332
    +22
    Hi, All blu ray titles have a dolby 5.1 or similar soundtrack (some less, Falling down is only in 2.0 stereo i believe), so you can listen to them via any amp.
  3. Grubert
    Grubert
    Jun 15, 2001
    601
    28
    +72
    That's not correct. Many discs (such as those from Fox or Universal) have only DTS (usually DTS-HD or DTS-MA, with a regular DTS core). So at the very least you need DD and DTS.
  4. petet66
    petet66
    May 11, 2006
    1,279
    63
    +157
    Or similar...? As I said mine is Dolby Digital only (or old school Pro Logic via analogue). Plus my amp will only output Dolby 2.0 as plain stereo which means I'll hear it but not in surround.
    Thanks for your help. Looks like I'll be needing to save even more pennies... :(
  5. Ian Dudley
    Ian Dudley
    Apr 28, 2006
    778
    +80
    What amp and BD player do you have? You might be able to use multi-channel connections to get HD audio on an older amp. It's not for the faint hearted, but is a lot cheaper than a new amp!
  6. neeek
    neeek
    Mar 11, 2003
    189
    28
    +37
    Do you have 5.1 analogue phono inputs on your amp? You could always get a player that does the conversion internally (I have the Sony BDP-S500 for instance) and then send the analogue signals to the amp.
    Edit - Spooky, great minds thinking alike there...
  7. nwgarratt
    nwgarratt
    May 5, 2002
    27,695
    +3,172
    You need a DD and DTS amp. They can be bought cheaply now if you don't intend to go all the way to HD sound. They go for around £50 on ebay if you use it.
    This is the model above my one and is worth keeping an eye on. Mine is still going after 9 years.
    Sony STR-DB940 Receiver
    Edit. As stated a BD player model such as a Sony 550 will do the conversion for you (and you get HD audio) if you have six analogue 5.1 phono connections.
  8. Ian Dudley
    Ian Dudley
    Apr 28, 2006
    778
    +80
    The DB940 has ext in connections, so could potentially do this. Not sure if it can do the bass management though?
    I had a DB925 until recently (two models down from the 940) when it died. I was able to replace it with a Denon 1907 from ebay for £80. That does all the DVD audio format, plus it has an Ext In with bass management and channel leveling which is ideal for doing HD audio on the cheap.
    I've just got a Sont S550 to do this and am just waiting on my first BD disc to put in it :thumbsup:
  9. petet66
    petet66
    May 11, 2006
    1,279
    63
    +157
    Of course :) Doh! My amp does have multi-channel audio inputs. All I have to do is slightly upgrade my choice of Blu Ray player. I had been looking at the Sony 350 but the 550 has multi-channel analogue out.
    When you say not for the faint hearted.... other than a spaghetti storm of cables what are the issues?
    Thanks again to everyone for their help and advice.
  10. Ian Dudley
    Ian Dudley
    Apr 28, 2006
    778
    +80
    Depending on how much you like balancing test tones, it can be a lot of fuss to get it sounding right. Bass management in particular can be quite awkward, especially with older amps. Plus some players and amps have odd quirks which can make it even harder.
    You can read about my trials and tribulations with the S550 here
    http://www.avforums.com/forums/av-a...0231-problem-decoding-bd-player-vs-amp-2.html
    Plus a new FAQ is just being put together in the Blu Ray players forum which talks through the issue of Bass Management in some detail.
    http://www.avforums.com/forums/blu-ray-players/1013651-blu-ray-audio-faq.html
    This is also a good general page on the topic.
    How To Set up a Blu-ray Player Using Multi-Channel Analog Outputs... And Why: BigPictureBigSound
  11. MartyMosh
    MartyMosh
    Jun 9, 2009
    Beer City
    Same problem here! Bought my receiver way back in '99...
    But can anybody explain, why DD is not mandatory for blu-ray?
  12. simonblue
    simonblue
    Jan 29, 2006
    19,588
    163
    +8,802
    Hi with Hd-dvd it was,but with blu ray it was left up to the studios,as it is a new format, it seem to have settled down with most studios,going for DD true or DTS master :)
  13. Grubert
    Grubert
    Jun 15, 2001
    601
    28
    +72
    That's not true. An HD DVD could be made without any Dolby Digital tracks as well (for example, the Terminator 2 HD DVD).
  14. Grubert
    Grubert
    Jun 15, 2001
    601
    28
    +72
    And back to the topic: Dolby Digital is mandatory on the players, not on the discs.
    I have some DVDs without a Dolby Digital track. For example, Björk Live Cambridge only had PCM stereo.
    The only difference is that DTS was optional with DVD, and mandatory with BD. For the players.
    The manufacturer of a disc must then include a PCM and/or DD and/or DTS track.
    Is that clear?
  15. petet66
    petet66
    May 11, 2006
    1,279
    63
    +157
    Yes perfectly thanks and explains some of the contradictory and confused explanantions I have found via Google.
    Still need a new amp though unfortunately... :)
  16. Ian Dudley
    Ian Dudley
    Apr 28, 2006
    778
    +80
    Not if you go the multi-channel input option. Any BD player will decode both DD and DTS (on DVD as well as Bluray). Most of them will decode all the HD formats as well and everything in between.
  17. neeek
    neeek
    Mar 11, 2003
    189
    28
    +37
    Thanks for the extra detail here - it's really useful. I have to admit that I was lazy and just turned up the volume on my sub, but this has me thinking that I really should take the time to calibrate things properly...
  18. Ian Dudley
    Ian Dudley
    Apr 28, 2006
    778
    +80
    In these days of plug and play digital connections, it can be quite involved. The ARC and primary audio quirks on the Sony drove me nuts till I figured them out.
  19. simonblue
    simonblue
    Jan 29, 2006
    19,588
    163
    +8,802
    :oops: sorry you right it was the players not the disc
