DNS + PSP + DLink
Discussion in 'Playstation Forums' started by azz0r, Apr 30, 2005.
  1. azz0r
    Ok basically the trick with wipeout (to get the browser working) is to change the connections DNS so the wipeout browser goes straight to a portal and not the sony site for wipeout.
    However I havent been able to get it working and with much investigation Ive found out that my router is causing the problem.
    Here are two quotes I found when investigating...
    Ok so using my router administration I went to the WAN area and updated the dns to use the portal DNS - but no luck, the router ignores it...heres an online dummy of it...
    So now Im just confused as to what todo...
