dns keeps dropping on my connection on live and the net
kopchoir
hi all i have just changed isp to talk talk on thursday went on line for the first time yesterday and my live connection keeps dropping when i test the live connection it fails on the dns im using a netgear dg834g and im connecting to the router via ethernet any help would be great
kop:smashin:
Mattk84
Can you connect at some times and not others? Has the problem only started since switching to talk talk ? I used to have major problems with my connection so may be able to offer advice but if this has only started since switching to talk talk it seems very odd as the line should be unchanged....unless your contention ratio is lower.
Finally why the heck would you want to go with talk talk?heard nothing but bad things about them!
oldnewbie
Established Member
I use talktalk and the same router :eek: But have had only one problem in over a year when the line went dead and I got through straight away and they diverted all my incoming calls to my mobile free and the problem was fixed within 6 hours, All I can recommend is try rebooting the router and checking all your filters are connected properly and then give them a ring if that doesn't work:cool:
kopchoir
thanks for the replys still having this problem
kopchoir
my connection with bt was fine apart from markwwwwwwwwwwwww...:D cable connection imo one of the best around so i have been looking at other options the thing is most company`s will only take you on if you have a bt line so back to bt after a week im not having my broadband with them though im going for this https://www.bethere.co.uk/homebroadband.do which will do the trick :thumbsup:
kopchoir
:smashin:hi boys thanks for all the invites as usual last night had some good games while they lasted looking into this connection issue in more depth today bt engineer came round yesterday nothing wrong with it :confused::confused: ill let you know what the script is i know your all missing me :D played some r6v campaign yesterday not played it in a while enjoyed it immensly and had a a few games with burt and wookster:hiya:on co-op got them an achievment your welcome guys yes im that good at all games:rotfl:
si:smashin:
edit google kopchoir:D:smashin:
⭐ Philips OLED+908 TV preview + REL subwoofer and Avid Accent amplifier reviews + Hi-Fi & AV News
Back
