DNIe with Samsung LE26R41B
Discussion in 'Xbox Forums' started by wormvortex, Mar 24, 2006.
  1. wormvortex
    wormvortex
    May 29, 2005
    5,765
    South of Heaven
    +443
    thought i'd post it here as alot of people seem to have the tv who post in this fourm.
    theres an option for DNIe which clearly makes the picture better but how do i turn it on, theres an option that says DNIe demo when i select that it splits then screen in half the left being with it off the right being with it on, the manual just says says when your happy with your choice press exit which just causes the words DNIe on screen to disappear then reappear a few secs later. Pressing DNIe on the remote simply turns the thing off.
    Anyone know how to keep it on?
  2. Carnagerover
    Carnagerover
    Jan 21, 2004
    3,682
    Rother'ham (donny lad)
    +223
    As far i as know is always on by default and you cant turn it off. The demo is just to shoe you the benefit your getting :)
  3. wormvortex
    wormvortex
    May 29, 2005
    5,765
    South of Heaven
    +443
    ah, so i wanna try and play with the brightness etc... so the left side of the screen looks like the right?
  4. Carnagerover
    Carnagerover
    Jan 21, 2004
    3,682
    +223
    No you dont need to do anything, the demo is just to show you the difference. The feature is on all the time no matter what. You cannot turn it off, the option option you have is to see the demo, to show you what its doing, even though it is on all the time :)
