Dmtech ?
Discussion in 'Plasma TVs' started by tamc98, Jul 8, 2004.
  1. tamc98
    tamc98
    Aug 13, 2001
    10
    Nottingham
    A friend has just bought a DMTECH DML-3117WD lcd tv/dvd. He now wants to be able to run it on a 12V feed in his caravan.
    Anyone know the makers web address or where I can find a 12V adaptor.
    TIA, Tony.
  2. technovorgin
    technovorgin
    Jun 16, 2004
    226
    Leeds/Wakefield border
    do you want to run 12 volt from 240 (maplins,tandy etc)
    or run 240 volt from 12 volt you'l need an inverter (maplins,truck stops etc)
  3. oni
    oni
    Does your friend know the DVD hack for this?
  4. mikedeakin
    mikedeakin
    Mar 2, 2001
    2
    The great thing about LCD TVs is that they all run on 12v anyway.
    We are fitting this model in our horseboxes, you just need to go direct from the 12v source in the caravan into the back of the TV where the adapter would normally plug in. You might need to make up a lead, using bits you'll get from Maplin.
    Mike
  5. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    If you need an invertor Maplin had a 400w (peak) on offer for iirc £14.99.
  6. Messiah
    Messiah
    Apr 22, 2002
    7,530
    +339
    Would it be worth trying the hack for their standalone DVD player? I don't own either so it's only a long shot.
    1. Press the Open button on your remote control to open the drive tray
    2. Press the Setup button on your remote control to open the drive tray
    3. Using your remote control, highlight the Custom menu
    4. Using your remote control, press the buttons 3, 3, 3 and 3, one at a time
    5. A previously hidden menu will appear where you can change the region setting to 1 for region 1, 2 for region 2, and so on, or select 0 for multi-region playback
    6 Press the Enter button on your remote control to open the drive tray
    7 Press the Setup button on your remote control to open the drive tray
  7. patmyhead
    patmyhead
    Feb 11, 2002
    588
    I o M
    hi
    i also require a lead for this tv to use the 12 volt supply in my motorhome to the 12 volt input on the tv
    i dont want to use a inverter to much hassle in the cableing etc
    would it be alright to just cut the lead where it come out of the 240 to 12v volt transformer & fit a ciggy plug
    pat
  8. tamc98
    tamc98
    Aug 13, 2001
    10
    Nottingham
    Pat.
    You should be fine doing this but you must make sure you get the polarity right or you'll blow the set up.
  9. patmyhead
    patmyhead
    Feb 11, 2002
    588
    I o M
    thanks
    how many inner cables are there is there 2 as normal or 4 as there are 4 pins
    bit scared of cutting the leads as if i balls it up it wont work on either 240 or 12 volts did you manage to get a 12 volt lead ready made up
    Pat
