DMTECH Wall Mounting - VESA Compliant?
Discussion in 'Home Cinema Buying & Building' started by cratliff, Aug 6, 2005.
  1. cratliff
    cratliff
    Have just bought a DMTECH DML-4117WD TV, and instructions advise for the wall mount "it has to comply with VESA Mount Interface 100mm standard". The instructions also state screwholes for Mount must be 100mm apart. So, bought one (and measured the screwhole distance, which is 100mm apart), but it doesn't fit the TV! The TV screwhole distance is about 110mm apart.
    Can anybody advise how I get over this???
  2. pilotsnipes
    pilotsnipes
    Just resurrecting this old thread.
    I've just bought a DMTECH LQ26, LCD tv, and I'd love to put it on the wall with a swivel LCD wall bracket. You know, the ones that you can extend out from the wall and then tilt up and down. Not the ones that hang ON the wall.
    The only problem is that I don't think it's VESA compliant. I've measured the mounting holes on the back of the TV and they measure (to the centre of each point):
    26.5cm wide (center of each hole)
    9cm High (centre of each hole)
    So, as far as I can tell this isn't VESA 200 x 100mm or VESA 100 x 100. Where the heck would I get a bracket?
    All info appreciated!
  3. pilotsnipes
    pilotsnipes
  4. tujax
    tujax
    Mar 28, 2005
    +6
