DMTECH TV remote code for BT Vision
Discussion in 'LCD & LED LCD TVs Forum' started by arkay, Jan 13, 2008.
Tags:
  1. arkay
    arkay
    Jan 16, 2006
    20
    3
    +6
    For anyone interested, the DMTECH code for BT Vision is 054. Remember, when actually entering the code to follow the instructions on page 13 of the Troubleshooting guide which require the extra 0. i.e. the full code is 0054.
    This works on my 17" LM-17X set. However, if this doesn't work for you try all the other listed AKAI codes in the "addition information" manual that came with your V-Box. Apparently, the codes for DMTECH are the same as AKAI...
    Hope this saves someone the 2 week search I went through. Right, I'm off to turn the volume on my telly up and down repeated using my BT Vision remote just because I can :D
    Arkay
