DMtech LM series 32" LCD combo
Kano001
Anyone got a hack to go regionfree? the only dmtech hacks I can find are for
other models. The 3,3,3,3 instruction takes you to a hidden menu but no
button on the remote and tv is able to move up & down the menu.
Kano001
Got 1:
DMTech DML-4126WD
1. Using the remote control, key in the following: Open, Setup.
2. Highlight the Custom menu with the remote control.
3. Using the remote control, press right three times (preferences or something maybe highlighted) then key in the following: 3, 3, 3, 3
4. A hidden menu should appear.
5. You can change the region setting to 1 for region 1, 2 for region 2,
and so on, or select 0 (or FREE on some models) for multi-region
playback
5. Press enter after your choice and press Setup again to leave the
Custom menu.
works for the 32" model.
