F
foxmeister
Hi there.
Just bought the above 17" widescreen LCD with built in DVD, very pleased with it so far.
I've tried to change the region to 0 by pressing 3 3 3 3 with the right cursor from the set up menu.
I can get the screen which states region 2 at the bottom but I can't seem to change the region to 0 by using the buttons on the remote (ie. number 0 or right cursor).
Could anyone help please ??
Cheers, Foxy.
Cheers, Foxy.
