DMTech 3117 LCD Widescreen with built in DVD Player
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by brichards, Aug 7, 2004.
  1. brichards
    brichards
    Jun 7, 2002
    164
    +16
    Hack for DMTech 3117 LCD Widescreen with built in DVD Player.
    Press set up with no disc inserted.Go to preference.
    Press 3 3 3 3 use right cursor to region change.
    Select 0 for region free.
    Press set up to EXIT. WALA region FREE..................................
    By the way what a brilliant PICTURE EXELLENT KIT
    Can be obtained at COMET.
    Brian Richards
    brichards@supanet.com
  2. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,001
    Southampton
    +233
    This also works for the DMTECH DML-4117WD. :thumbsup: :)
  3. Inkpot
    Inkpot
    Thanks. I had been struggling to reset the DVD payer to milti-region until I read this. 2 minutes later........sorted!!!
    Brilliant.:)
