DMTECH 17" Combo Power Problems
russellbaldwin
I have a 17" DMTECH LCD DVD Combo unit. Had it for a couple of years without fault but it now has an intermittent power problem which is getting more frequent (and frustrating). The unit remains on standby with the light displaying on the power button. When I hit the power button the light will sometimes flash avery second or so as if the unit is trying to power up, gets stuck and then tries again. The TV sounds like it starts to humm and then clicks off the power.
There's no answer but to turn unit off at the plug but this doesn't usually fix it. Leaving the unit off for a couple of days sometimes sorts it but it's very frustrating!! Any help would be appreciated!!
thanks
Kano001
Sorry to bring up this old thread guy's but I have the same kind of problem on a 37" combo, typically it happened a few hours after I sold it and the guy turned up at the door to get a refund, so I now have a tv sitting doing nowt, is it an easy fix or am I better chucking it?
Regards.
Kano001
Just to elobaorate further on this, symptoms are when tv is turned on the power led just flashes & the tv cycles through it's on/off routine in a constant loop, sounds like it's turning on then off etc...
I have googled many a thread on this and have never come up with an answer. DMtech uk are no help as it's been out of warranty for at least 2 years and want me to send the tv, not prepared to do this if I can fix it myself.
Regards.
Podcast: Samsung HW-Q800A Soundbar & Rotel Michi X3 Reviews + TV show and Movie News & Reviews
