DMREX75 - Record from Sky in RGB??
Discussion in 'Blu-ray & DVD Players & Recorders' started by johnlg, Aug 28, 2006.
  1. johnlg
    johnlg
    I'm about to taake my SOny 525 back and have a Panny DMREX75. Can anyone confirm recording Sky will be RGB with this?
  2. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,119
    +7,017
    Yes - The EX75 will intake RGB to record. [ and will also pass-thru RGB from AV2 to AV1 ]
  3. aekostas
    aekostas
    Jan 2, 2006
    1,263
    48
    +52
    The DVD can do it. I don't know if your Sky box will output RGB for recording though. My Freeview boxes don't.
  4. Archie Fax
    Archie Fax
    Nov 23, 2003
    233
    Kent
    +10
    If I remember correctly, sky boxes output rgb so long as you enter the picture services menu and tell them to. The rgb output is on the scart socket marked ‘tv output’ on the skybox. The scart socket marked vcr out is composite only.
    So you have to connect the dvd recorder to the ‘tv out’ scart socket on the back of a skybox, to record rgb signals from a skydigibox.
  5. rcoll
    rcoll
    Mar 6, 2006
    83
    11
    +8
    and dont forget when recording from SKY, dont press the "TV" button on the sky remote during the recording. Pressing TV will switch the scart output on the sky box from RGB to composite. If you have set up you recorder to accept RGB only you will get a black screen with sound. It took me a while to work out what happened after i was getting many blank recordings:rolleyes:
  6. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,119
    +7,017
    Have you any idea of the point of this peculiarity?
  7. rcoll
    rcoll
    Mar 6, 2006
    83
    11
    +8
    besides being really annoying, i can see why sky does this. My old (4 years +) box and remote did exactly the same thing. The only thing i ever used it for was to demo the difference between RGB and Composite when viewing through the scart, press "TV" composite picture press "SKY" RGB picture back on , repeat as necessary.
    If anybody know why this is the case i would be curious to find out. As i said i have lost a few recording becasue i pressed "TV" on the Sky remote to allow me to power off my TV, not realising that the RGB signal also switched off and resulted in a blank (with sound) recording :mad:
  8. zappo
    zappo
    Nov 7, 2005
    683
    +47
    I thought both Sky Scarts output RGB as long as it is set in the menu. Is that documented somewhere?
  9. Archie Fax
    Archie Fax
    Nov 23, 2003
    233
    Kent
    +10
    The skyboxes I use are made by Pace. They only output rgb on the tv out scart socket which is mentioned at the back of the instruction book under 'rear panel connectors'.
  10. User101
    User101
    Feb 1, 2006
    16
    Thankyou!! This has been driving me mad trying to discover what was causing the odd blank recording. I will never use the sky remote to switch off the tv again.
