DMRES10 & Wide Screen
Discussion in 'Blu-ray & DVD Players & Recorders' started by jm1, Jul 27, 2005.
  1. jm1
    jm1
    Feb 9, 2003
    371
    28
    +90
    Could someone with a Panasonic DMRES10, tell me if it only records in wide screen when recording to DVD-RAM, or does it record in wide screen with all formats?
    jm
  2. ArtS
    ArtS
    Unfortunalety it records wide-screen to DVD-RAM ONLY. For other media it streches picture horizontally.
    Sorry, ArtS :thumbsdow
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,710
    Warwick
    +2,586
    Just to elaborate slightly: DVD recorders record the Widescreen Switching Signal (WSS) when you use VR mode - be it to a DVD-RAM or DVD-RW (VR Mode)* - but not when you use Video mode (DVD-RW, DVD-R, DVD+RW, DVD+R). It's inconvienant but all you have to do is manually select the '16:9' button on your TV. You can also use a programme called IFO Edit to restore the WSS onto your recordings.
    * Note the Panasonic range do not record in DVD-RW VR Mode.
  4. jm1
    jm1
    Feb 9, 2003
    371
    28
    +90
    Thanks for your replies, I don't think it will be too much of an inconvenience to manually select 16:9.
    jm
  5. MikeMcr
    MikeMcr
    Jan 8, 2003
    401
    Manchester, UK
    +16
    This is not the case with Pioneer and Toshiba recorders; they correctly set the widescreen flag in Video Mode DVD-R. There is no reason why Panasonic cannot do the same, except for laziness on the part of their programmers :rolleyes:
  6. Rasczak
    Rasczak
    Apr 3, 2002
    21,710
    Warwick
    +2,586
    The situation is slightly different there - a menu option to set it is available before the DVD is burnt from the HDD. If you look at the link in my signature the situation is explained more fully.
  7. MikeMcr
    MikeMcr
    Jan 8, 2003
    401
    Manchester, UK
    +16
    Not with the Pioneer DVR-520H which I have. It is all automatic; you cannot override the setting but up to a specific quality setting, the 16:9 flag is automatically copied to DVD-R video mode media.
    It copes with the multi-aspect title problem by warning you that a title cannot have mixed aspects and it then splits one recording into multiple titles when you are building your copy list. Each part then has its own aspect flag. A nice side effect of this is it's great for easily getting rid the adverts when a programme has different aspects since the ads are already split for you!
    I just wish Panasonic would do this as there is no reason they can't.
    Yes, it's not a big deal to press the aspect button on the TV but why should we? These recorders cost a lot of money and basic features like this should work; it's actually quite frustrating trying to explain to non-technical relatives about aspect ratios.
  8. gavan
    gavan
    Dec 20, 2001
    3,984
    Rapture
    +286
    Yep - the stupid oversight in the inability to record the widescreen switch signal is one of the niggles that made me sell my Panasonic EH50. It's absolutely stupid to not at least give the user the option to manually set it prior to recording. Who cares about not being able to switch the ratio mid-programme? Most people will cut out the ads anyway, which would be one of the few reasons for a mid-programme switch to be needed.
    If you have a lot of recordings in differnt aspect ratios, the last thing you want to do is be guessing the ratio and having to set the TV manually every time you play a recording. Also, giving the discs to other people you'll generally have a hell of a time trying to explain the ins and outs of having to switch the aspect ratio as needed, to them.
    Gav
  9. MikeMcr
    MikeMcr
    Jan 8, 2003
    401
    Manchester, UK
    +16
    I completely agree. It was so disappointing to look at the PDF manuals for the new Panasonic Freeview models and see they still cannot record the 16:9 flag onto DVD-R. I refuse to buy one while that (forced) limitation exists.
  10. Rasczak
    Rasczak
    Apr 3, 2002
    21,710
    Warwick
    +2,586
    Your missing the point - the ES10 being discussed in this thread is not a HDD machine - it's a standalone. What your HDD machine does is different from recording the 16:9 directly onto the DVD in Video mode - you're converting VR mode to Video mode. As I say the situation is explained fully in my signature...
