DMRES10 recording problem
marklfc77
I am still having problems with my dmres10 I have been having quality & problems when recording, the first problem was I was having a vertical line down the screen which moved left to right and sometiomes ghosting of words on the screen which also moved left to right, it was suggested that i replace my scart leads which seemed to have cured the problem I think as it wasn't as noticable, but I recorded Deadwood the other night which I timed it recorded ok, but there was a problem sky was set to autoview the recorder turned itself on and started recording before sky came on, like I say the program has been recorded ok, but when the recorder was recording a black screen as sky wasnt on at the time, it was recording a soundtrack from another program, so I still seem to be having a problem with a program overlapping the recording.
secondly I recorded a football match on DVD Ram on Lp the quality wasnt that good it was a bit blurry like it wasnt keeping up with the play, and when the camera angle change to a close up the quality was awful at times like the pixels had all broken up.
anybody got any advice that is if you can understand any of the above??
ROYOLD
Sorry I didn't read your posting properly. It cannot be the aerial if you are recording from Sky. I assume that your terrestial reception, actually via the aerial is OK (This is analogue TV reception). Which seems to suggest a problem between your recorder and the scart box. A badly pixellated picture on the freeview channels usually indicates bad signal strength. I record on LP to my Panasonic with DVD-RAM and its usually fine. Blurring of quick movements can sometimes be a problem on some LCD TV's whether it is on a ram disc or not.
Amazon Fire TV Cube Gen 3 Review: Coming Soon
