DMRES10 multiregion?
Discussion in 'Blu-ray & DVD Players & Recorders' started by x5tjf, May 11, 2005.
  1. x5tjf
    x5tjf
    Apr 13, 2005
    77
    +5
    I recently bought a Panasonic TH42PE50 plasma screen and got a DMRES10 recorder bundled in the package. At the time I was not offered the multiregion capability on the DVD recorder (but now it is being offered for an extra £10 !!) or I would have paid for this as I have a collection of region 1 DVDs.
    I understand that converting the DMRES10 to multiregion is just a matter of putting a special Panasonic DVD into the drive and pressing Play?
    Given that I live in N. Ireland so it will probably cost me £20 or so each way to send the recorder back to the UK mainland get this fixed. Does anybody know how I can get hold of a special Panasonic DVD disk or if there is anywhere locally in NI that I can take the recorder to get this upgrade done?
    Many thanks. :confused: :confused: :confused:
    Terry
  2. Freddo14
    Freddo14
    May 11, 2005
    27
    3
    I'm no expert but I was planning on getting the same recorder and I found these guys
    http://www.dvdchips.co.uk/
    who sell a weird remote thingey that ought to do the trick, apparently.
    hope thats helpful.
  3. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
