DMRE550 Video from firewire/Audio from external scource?
Discussion in 'Blu-ray & DVD Players & Recorders' started by barry1901, May 6, 2005.
  1. barry1901
    barry1901
    May 4, 2005
    7
    I intend to record directly from a camcorder to a Panasonic DMRE500HEBS via the firewire facility, as the subject is some distance away would it be possible to simultaneously record the audio from an external mike connected directly to the DVD recorder in preference to the audio on the firewire link?
    Thanks in anticipation.
    Barry.
  2. Benfica
    Benfica
    No.
    You can however do one of these two things:
    - You can connect your camcorder through S-Video to your DVDR recorder and connect your external mic to DVDR recorder.
    - You can connect you external mic to your camcorder (if it has that option), and in that case connect the camcorder to DVDR through firewire.
    HTH
  3. barry1901
    barry1901
    May 4, 2005
    7
    Hi Benfica,
    Thank you for the swift and informative reply, at least now I know, I think I will take your first suggestion ie S-VHS and external mike.
    Cheers,
    Barry
  4. Benfica
    Benfica
    Ok.
    But you are aware that you are compromising on PQ (picture quality) ? I mean, a firewire connection from your camcorder to DVDR recorder is better then a s-video connection.
    HTH
  5. barry1901
    barry1901
    May 4, 2005
    7
    Hi Benfica,
    thanks again for the turbo fasty reply, yes, unfortunately I am aware of the drop in quality but I have had very mixed results from using the fiddly little audio inputs on camcorders.
    Cheers,
    Barry.
