DMRE500 Remote
Discussion in 'Blu-ray & DVD Players & Recorders' started by Steve N, Oct 14, 2005.
  1. Steve N
    Steve N
    Feb 3, 2005
    10,944
    Peterborough
    +2,390
    Anyone know where I can get one of these cheap.
    Mine works perfectly except the fast/slow-forward/back buttons which you have to press almost through the metal (plastic) for a response.
    The machine is still under guarantee but I'm sure that if I returned the remote, I'd get one of those "we can't find a fault" replies. Also, I use the machine daily, So don't want to be without a remote for weeks until they decide not to replace it.
  2. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    Do you want the original remote? I'm guessing they'll be fairly expensive. Would a generic all in one type remote suffice? If you do want the original type I would first try your local [email protected] As a final last resort you could try contacting Panny customer support. I must say my remote has no such issues.
    S.
  3. Overlord69
    Overlord69
    Mar 17, 2005
    781
    +55
    Hi Steve N,
    Try the official UK Panasonic online eShop "Click here".
    Panasonic DMRE500 "EUR7721KN0" Remote control @ £23.62 ;)
  4. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    Bargain, not as bad as I thought it would be. :thumbsup: I remember years ago having to buy a replacement remote for a Sony TV and at the time I think they wanted close to 80 quid for it, seems times have changed. Good luck getting your replacement sorted Steve!
    S.
  5. Overlord69
    Overlord69
    Mar 17, 2005
    781
    +55
    Panasonic are a rarity they don't rip you of on replacement remotes. Mine arrived 2 days after placing the order. :thumbsup:
  6. Steve N
    Steve N
    Feb 3, 2005
    10,944
    Peterborough
    +2,390
    I had the same experience with my Sony TV a long time ago. The new remote was going to be £110. This was about 1988. I ended up getting a new TV.
    At the time I was a Coop stores controller and so I bought my new Sony through one of our electrical depts and the manager wangled me a spare remote for my new TV.
    It seemed to be just a few weeks after this that all purpose remotes started coming available.
    By the way, I have still got this brand new -17 year old remote if it's any good to anybody.
    *EDIT* glad to see that you have had no problem with your remote. I was concerned that it may be something typical of the design.
  7. Steve N
    Steve N
    Feb 3, 2005
    10,944
    Peterborough
    +2,390
    Thanks Overlord - thats brilliant - can't believe the're that cheap :thumbsup:
    PS - I posted a thank you prior to my last post but I see its disappeared :confused:
  8. Overlord69
    Overlord69
    Mar 17, 2005
    781
    +55
    Glad I could help buddy. :)
