DMRE20 "U11" Error
Discussion in 'Blu-ray & DVD Players & Recorders' started by Rasczak, May 26, 2002.
  1. Rasczak
    Rasczak
    Apr 3, 2002
    22,128
    Warwick
    +2,990
    Can anyone help me with an error am geeting when trying to copy VHS tapes over to DVD-R on the DMRE20? I am using Pinco DVD-R disks - I insert the disk and press Record - it 'records' for 20 seconds or so and then 'U11' appears on the display on the machine and a second or two latter it turns itself off. When I switch it back on the disk is still unused.
    I am using Princo 4.7GB DVD-R disks.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    22,128
    Warwick
    +2,990
    In an update to above...if I keep trying it eventually gets going and then it records ok. I had no problems transfering other VHS videos to DVD-R although I admit this is a somewhat older tape (of Day of the Triffids).
    Can anyone shed light on this U11 error?
  3. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,641
    London
    +477
    Yes it is a disk error.
    It has absolutely nothing to do with your source material from VHS or otherwise.
    You're Princo's are no good. Usually they are OK but some batches are 1st gen disks and you'll have poor luck with them. Insist on Princo 2nd gen when you buy next time.
    Try alternate brands like FWS 2nd generation or the newly available 3rd gen ones which generally work superbly.
  4. Rasczak
    Rasczak
    Apr 3, 2002
    22,128
    Warwick
    +2,990
    Cheers - I'll try different disks in future. I have made a number of VHS copies successfully - should I redo these on new disks or are they OK if the recording has been successful?
  5. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,641
    London
    +477
    If they have recorded fine then I don't see why you should waste what you've done ?
    However the good thing about the later better quality disks is they will play in far more 3rd party dvd players than the early cheap disks.
  6. malcom
    malcom
    Aug 25, 2001
    526
    +4
    Rasczak
    I tried Datasafe discs and they failed in the manner you describe but I saw no error message, the machine just shut down.
    The supplier told me that Datasafe is in fact princo so i would avoid them too. Although a later generation disc may perform ok. I am using FWS branded at the moment.
