Quantcast
DMRE100 Editing
Big Al
In direct navigator use the partial erase button. this will allw you to select a start point & end point. You can repeat this process as many times as required.
Big Al
Big Al
No problem, & welcome to the forum
Big Al
OARDVD
Originally posted by samraj
I was looking for a 'lazier' solution!! Thanks
Hi Samraj. Well there's no automatic solution but sometimes it's a little easier to edit if you first add markers either side of the ads. Then later, when you go into 'Partial Erase' or 'Divide' you can use the >> fast forward key to jump to the markers.
