DMR-XS380 not allowing automatic clock setup
Discussion in 'Blu-ray & DVD Players & Recorders' started by andyfr, May 17, 2018.
  1. andyfr
    andyfr
    Apr 10, 2003
    246
    Highlands, UK
    +5
    I recently bought a brand new (old stock) XS380 as I wanted to use my XS350 in another room. When I try to set the clock to Automatic I get the following message: "Clock cannot be set automatically. Please set the clock manually."
    The clock also doesn't change automatically for BST or GMT and if the power is off for more than a couple of minutes it has to be set from the default date of 2010.
    My old XS350 is fine and is set to automatic and picks up the time from the satellite.
    I would be most grateful for any help with this.
  2. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,069
    +6,947
    Did you enter your postcode during the setup procedure?
    This can be required to provide certain services.
  3. andyfr
    andyfr
    Apr 10, 2003
    246
    Highlands, UK
    +5
    Thanks for your response. Yes I did enter the postcode.
  4. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,069
    +6,947
    The unit picks up the time from one of the digital channels it receives ( but I don't know which )
    Typically it always used to be BBC1. If the appropriate channel is not being received, that might cause such a problem.
    Other than that, all I can suggest s a full power reset ( 15 minute mains disconnection)
  5. andyfr
    andyfr
    Apr 10, 2003
    246
    Highlands, UK
    +5
    All channels received, i will try a 15 minute mains off tomorrow and let you know.
  6. andyfr
    andyfr
    Apr 10, 2003
    246
    Highlands, UK
    +5
    I tried that by leaving the power off for an hour but still the same issue.
    I will have to put the old XS350 in the main viewing room as that is fine.
    Thanks anyway for your suggestions. :)
