benjamine1979
Hi All,
Can someone help me. I have just set up (or tried to set up
) a new DMR-EX78 and a TX-32LXD85. I thought it would be easy and I followed the manual to the exact.
After setting up all the channels on the TV completed I moved onto setting the channels on the DVDR. That is where it all went a bit pear shaped. The onscreen menu appeared ok but when I went into the DVB auto set up screen the picture disapeared and started flickering. All the other menu functions appear which is really odd.
The bit that has confused me is that the manual says you need a scart and a HDMI lead. I wonder if this is was is causing my issue as I have both currently connected???
